120mm Blue LED?
I didnt look very hard for my fans, but the Coolermasters I got are 120mm with 4 blue leds in'em, and they say they're rated at 22db and 42ish cfm. NCIX has'em
I like the coolermaster LED and UV fans...
Probably the best coloured fans, but I gave that up for better performance :).
I use the Antec Tricools, but they tend to be a little on the loud side if they are turned up all the way.
I use these on my radiator and love em. Kind of pricey though; I think SVC may carry them for less.
baballin328 said:
He wants to keep all his ordering to newegg. So is this good? http://www.newegg.com/Product/Product.asp?Item=N82E16811999153 I know its 80mm but he can either get a 120mm or a 80mm.
I bought that pack of 80mm fans and I think they're good.
If they have a 120mm fan, I say buy them...
But if he really wants blue led fans and high cfm then get these
http://www.newegg.com/Product/Product.asp?Item=N82E16811999122
I have two of these 120mm on fans on my Thermaltake Big Typhoon and they work good.
Rabid Badger said:
How did you mount 2 fans on a Big Typhoon?
I took the side of my computer case off.
J/K
I put one in the normal position and one on the side
blowing the air to the fans in the back of the case...
From the side window, it looks like the second fan is sitting
on the video card, but I put a piece of Styrofoam under it so
both fans are level. Why did I do it? Something to do.
In Total, I have 5 TT 80mm Blue LED case fans.
And 2 blue LED 120mm TT cpu fans.
I bought 2 of those four packs of the 80mm TT's,
so I got some spares as well.
Shit my keyboard and mouse pad glow blue as well.
baballin328 said:
so are the fans in that pack quiet?
My whole case is quiet enough for me and it sits off the floor about a foot,
right at the end of my desk. So, it's about two to two and a half feet from my lcd screen.
I here a humming or air sound constantly but I've put up with it this far, which is a few months now.
Could they be quieter, hell yes, but do I want to throw my computer out the window? "No".
Plus if you get a pack of 120mm TT fans, they should move more air with less noise anyway.
Win, Win to me...
Another thing, my room isn't the biggest and I keep my puter on 24/7 364.
I have 4x 120mm Antec Tri-Cool in my rig. They are very bright and come with 3 speeds built into them. I have to say they can be loud on the highest speed, but it shoots out 79CFM.
I have the rear exhuast blowing full speed and the other 3 set to medium. The noise isn't that bad that it drives me crazy and it sits on top of my desk right next to me.
I have 2 Aero Cool Turbines (they look like jet engines heh). One sucks in air, the other blows it out. The run at 90CFM :p
I also a blue-gears 120mm blue led dan that sucks in about 60CFM, so I've got two filtered intakes and one exhaust, so it should balance out considering the filters to restrict some airflow.
