i just spent $30 on a 120mm Papst 4312MV two speed "Variofan" thinking it would work with an 80MM adapter on my heatsink. i was hoping i could tinker with it and get it to read my socket temp with a sensor attatched.
the problem is, the adapter creates pressure and it lets half the airflow leak back out around the edges of the blades.. i just sat in bios and watched the socket temp climb to 65 before i shut it off. is this 120mm > 80mm idea wrong?
anyone have this fan and know how it works and how to get it into high speed? here's its connection:
here are some of the fan specs (the only specs i can find at all. even from all of Papst's spec sheets and catalogues).
edit: ive also got this thread at Silent PC Review.
Code:
front of the molex, wires behind.
_________
/_O_O_O_O_\
blue & red
purple
(NTC)
