Finally, there may be a third true 120Hz monitor from ASUS in Q3 2009; with the flaws in the first two monitors, it may be worth waiting to see if ASUS does it right.
The only two true 120Hz monitors are the Samsung 2232rz and the Viewsonic VX2265wm. These are both 22" 1680x1050 monitors, and they will take 120Hz from the video card. All LCD TVs that advertise themselves as 120Hz, 240Hz or even 480Hz only do that internally, and actually take 60Hz or less from the video card.
Somewhere on the forums I saw someone compare the Samsung and Viewsonic but I can't find that comparison anymore. One of them was better than the other is all that I remember. I have not seen any rumors of more true 120Hz monitors yet, so there probably isn't any other choices coming very soon.
Edit: I see in the Viewsonic VX2265wm thread here that the Viewsonic has apparently very low or no input lag, but it is stuck on 100% brightness when in 120Hz mode and has high backlight bleed, which puts a damper on my enthusiasm for that monitor. The Samsung 2232rz is criticized for having poor color accuracy (too blue) and average 10ms to 12ms input lag going up to 25ms (why make a 120Hz monitor with input lag?). Finally, there may be a third true 120Hz monitor from ASUS in Q3 2009; with the flaws in the first two monitors, it may be worth waiting to see if ASUS does it right.
All day and all night, all he sees is blue, like him, inside and outside...Samsung love making their monitors too blue. I bought one half a year ago and it was too blue and many of the samsung TVs I've seen had too much blue, as well as several Samsung monitors have been criticised in reviews for being too blue.
i finally got the vizio 47" 120hz setup with hdmi... with sound over hdmi on a 2600p perfectly. that screen makes my samsung 225bw look like someone took a soupy shit on the front and smeared it all around with their face.
i did notice some very slight studder here and there... i wasn't sure if it was the 3800+@stock speed struggling (the vid card should handle the encoding though) or if i was seeing the 60hz feed being upped to 120hz by the tv.... overall though, it was like looking through a window, not at a tv.
