Retsam
- Sep 2, 2005
I just bought a new Viewsonic VX2268wm 120hz monitor. I am coming from a CRT so, this is the first time ive had to deal with a 120hz flat screen. I run an AMD MSI 5770 with 12.1 cats.
Need a little help here. I run my deskstop at 1680x1050(native) @ 120hz. I am having an issue at below native resolutions though.. It seems every non-native resolution I set does not run at 120hz no matter what I do. Anyone have an idea why? I want to game at below the native resolution. I have tried a variety of other resolutions and its always at 60hz.
I have set force refresh rate in Cats to 120, that does nothing. I have set the force refresh rate to use same refresh rate as desktop, that does nothing.
Also, what is a program that will display current refresh rate and resolution? I noticed in Skyrim, even when my res is set to something other than native, in the monitor information setting, it still shows the deskstop resolution @ 120hz, but its obviously not at that resolution or that hz.
I did notice two DVI settings in Cataylst drivers and I have no idea what they are for. x) Reduce DVI Frequency on high-resolution displays and x) Alternate DVI operational mode. I have both deselected. Is LCD overdrive supposed to be enabled? Value?
