Hello
Just thinking about the difference between 24 inch 1200p ( 16:10 ) and 27 inch 1440p (16:9) and then 30 inch (16:10 ). I checked how much more space I can get and the 1440 screen will be 20 percent bigger.
( physical size of the screen ) That what I understand actually.
But if you compare resolution of 30 inch which is 2560x1600 to 27 inch 2560x1440 ( almost same isn't it? ) you get much smaller screen. I believe pixels have to be smaller. So summarizing: lets say an image of 2560x1440 will entirely fill the 1440p screen leaving only like 160 pixels on the biggest screen. And the question is : Will image on the 1440 screen be much sharper and clearer? It could be a trivial question for some of you and would have been brought up on the forum - but could you once again clarify this please?
I really do not know which screen I should go for - 30 inch or 27 one. Any suggestion will be appreciated.
