1200p and 1080p Eyefinity
Tahoe916
Anyone have a center LCD 1200p and sides 1080p? NOT at the same time, I understand how Eyefinity works, just wondering if anyone has a 1200p center screen running 1080p along with the side 1080ps and how it matches up?
I guess it depends on scaling, I wish 1200p 24" monitors weren't harder to find than that magical g spot. :(
It should work but they will all run at 1080p.
EDIT: Oops, didn't read properly, sorry. Ignore. ^.^
If they are the same size, then there shouldn't be any problems. Your output resolution would end up being 5760x1080.
If you wanted to match, say, a 24" 1200p monitor then say 23" 1080p monitors on the side then I wouldn't suggest it.
Actually I ran a 23" 1080p next to a 24" 1200p the other day in Eyefinity and since the 1200p letterboxes down to 1080p it ended up the same image size as the 23" 1080p. I didn't investigate it but it sure looked like the same exact size. I'm sure there's some math you can do to find exactly what measurement a 24" 1200p letterboxes down to.
If you used it at stretch you'd probably need a 25" 1080p to match height with it which is more important than matching width.
I think you'd prefer the 1920x1200 res if you can stick with them though, the extra height helps since you get so much width in Eyefinity.
I recently picked up a pair of Samsung 2433bw monitors brand new on ebay for $200 each. They are 24" 1920x1200. They work out nice since I stagger my two side monitors in front of my center one. I'm sure there are better setups out there, but since I was buying on a budget I did the best I could. If I had 2k I'd buy that Samsung Eyefinity setup coming out, with 3 2560x1600 monitors with ultra thin bezels. Considering its 3 30in monitors, thats actually a damned good price.
edit: Samsung md230
http://www.engadget.com/2010/01/08/samsung-and-ati-team-on-syncmaster-md230-mega-displays-for-wide/
the samsung md230 isnt a 30" 2560x1600 monitor... i dont care what all the early release sites say
the 230 in the name means its a 23" monitor... the resolution is going to be 1920x1080 / 3 monitors and a stand is what you get for a msrp of $1899
not 3 30" monitors and a stand... think about it... a single 30" is close to $1000
if samsung were selling 3 plus a stand for less than $2k that would be the deal of the century...
Thanks for the input guys, I think I will try and source some 24" 1200p monitors, I think it would bug the shit out of me if they didnt match up just right lol.
