Brad Gamma
- Jan 9, 2008
Hey there
I have some questions about an upcoming build. I want to put together a mini-itx rig for my girlfriend since her PC just broke.
I am currently looking at this case to house the following components:
e5200 2.5ghz cpu
DG41MJ mobo
passive hd 4550
250gb lap-top hard drive
slimline optical drive
4gig of ddr2
I am looking at this case in particular because I am picturing it after doing a paintjob (so if I changed case it would have to have blank sides etc.). This particular one though comes with a 120 watt PSU, raising 2 questions.
1)Will a 120 watt PSU power these things. The graphics card is powered through the mobo so I dont need the connection for it. I think the hd 4550 peaks at about 20 to 30 watts. I currently have a HTPC with an e5200, dg45id mobo, 2 1tb drives, dvd drive and 2 case fans that idles at 37 watts and I cannot push past 70 watts at the wall. So this system would have less hard drives, one less case fan, but a low end gpu added. However my understanding of PSUs beyond their max power is pretty poor. Would this be okay?
2)Should I trust a generic PSU? The only PSU that came with a case that I have used was an Antec one. I've always invested in a good brand PSU to avoid any problems, but I've also never bought a case that came with a no-name PSU, so I've never had to waste one. Is it a bad idea to trust the one in this case? It looks the same form factor as some small narrow seasonic PSUs I can buy (and up the wattage at the same time), but I'm not quite sure if its built into the case or not from the pictures. Any tips? Is it a bad Idea to trust the PSU if im trying to squeeze power out of it?
Feel free to point to other attractive mini-itx tower cases without PSU's or with good PSU's that end up costing me £60 for both
(I can get small seasonic 200W ones for £30)
e5200 2.5ghz cpu
DG41MJ mobo
passive hd 4550
4gig of ddr2
