120 for 59 kingston ssd
Evidently not, nor are they likely to if you give no further information. :)
Microcenter has for the same price.
http://www.microcenter.com/product/..._III_6Gb-s_25_Internal_Solid_State_Drive_(SSD)
Sure the speed may not be "as advertised", but if your looking at it at this price range I'm sure you will be more then happy the performance.
No you wont. They are slower then cheap knock off USB drives at times. You would be much better off buying an older higher end SSD here on the forums from a good seller then ever putting one of these POS units in your system.
I'll second the notion that yuou won't be happy with these long term. They are unreliable POS with spotty performance. I will NEVER buy another kingston SSD, ever.
Is English your native language? If so, you should work on your spelling.
There are differences between "your", "you're", "then" and "than".
My manager is so smart that he types slower than he thinks and often leaves words out, such as you did with both sentences. Though I understand the intent of your message, you don't offer any metric regarding how "happy" is measured with regards to the performance. Happy is a relative term, and is different for everybody. Personally, I would rather buy a 128GB Crucial SSD for $67. Or wait for a better sale on a 256GB model <$100, which occurs at least once every couple of months.
I share the same sentiment as many others here. Kingston fucked up BIG time, and a mere 10% cheaper than the competing SSDs will not entice me to purchase their product. If I see a 120GB V300 for say, $30, then I'll consider buying some.
Just to get the facts in here:
http://www.anandtech.com/show/7763/an-update-to-kingston-ssdnow-v300-a-switch-to-slower-micron-nand
Code:
Comparison of Kingston V300 Revisions
Revision	Original (no longer available)	New (currently available)
Pre-Istalled Firmware	                        505A                           506A / 521A
                                          NAND Toshiba 19nm       Micron 20nm asynchronous
NAND Interface Bandwidth	                  200MB/s	            ~ 50MB/s (?)
AS-SSD Incompressible Sequential Read
                                             ~ 475MB/s                     ~ 170MB/s
AS-SSD Incompressible Sequential Write
                                             ~ 150MB/s                     ~ 85MB/s
AS-SSD Incompressible 4K Read
                                              ~ 20MB/s                      ~ 15MB/s
AS-SSD Incompressible 4K Write
                                              ~ 110MB/s                    ~ 65MB/s
So, these drives are at BEST, 25% slower than the reviewed original V300's for incompressible 4k Read,
Worst case is 75% performance DROP
GEE, Why not a 75% drop in price?!
While I'm on a roll, (yes, I'm feeding the troll)
http://www.anandtech.com/show/8792/transcend-ssd370-128gb-256gb-512gb-review
Transcend 128GB drive is $63 shipped at newegg
And guess what? It has FAR better performance than the V300.
Sorry, I had to post links for a factual rebuttal and reason why I disagree with the statement "at this price range I'm sure you will be more then happy the performance"
