cornelious0_0
- Apr 6, 2003
Hey all, just wondering if I might be able to get away with a 120.2 radiator to watercool my CPU and GPU. My E8400 is currently sitting at 4GHz /w 1.328v and currently loads at 57c on air. The GTX260 is running at stock clocks/voltages and is not OC'd at the moment.
Would it be possible to put the E8400 and GTX260 in the same loop using only a 120.2 radiator? I would only have room for 120x25 fans on one side of the radiator inside my TJ08 so push-pull setups are out of the question.
I don't mind louder/faster fans if need be, I just need to know if I'd be able to pull it all off without making my temps any worse. I'm not looking for huge gains, just a bit of a temperature drop as well as the "wow factor" of setting up another h2O loop cleanly inside my new mATX case.
Input is greatly appreciated, thanks in advance you guys.
