brewcrew814
- Oct 27, 2005
Hiya everyone,
I'm going to pick up a GPU in a couple weeks for my brother, I was hoping for some feedback. He's running a
9600 PRO AGP
1024 MB (PC2700 DDR SDRAM)
AMD Athlon XP, 2157 MHz (13 x 166)
Like myself he's not going to be building a comp for 9 - 12 months. I'm not sure what powersupply he has ATM. He has a HP he bought from CompUSA. Anyway, I'm looking at these two GPU's and was wondering which would be the best.
This one only has GDDR2 memory.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2427400&CatId=318
This uses GDDR3 memory, wasn't sure how much of a difference it would make.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2201323&CatId=318
My Brother/Nephews use mainly for WoW, CounterStrike and most likely will be playing Vanguard. I wanted to get him ready for the release. Any input would be appreciated.
Also, If you have a better suggestion than the 2 listed I'm open for that also
Again, I'm trying to stay from 100 - 150 dollars, This comp will be used approximately 9 more months before a new build.
9600 PRO AGP
