i just upgraded a few parts and im testing out some oc numbers.
im not looking for bleeding edge numbers, just a nice balance between a small oc and acceptable temps. i just adjusted the multi to see what results i could get. tested using occt v4 for 1 hr. i know under normal gaming use you never reach these loads, but im wondering what setting would be acceptable for a 24/7 oc.
cpu@ 3.3 (stock)
cpu idle 31, max 44
cores idle 19, max 31
cpu@3.5
cpu idle 32, max 47
cores idle 19, max 37
cpu@3.6
cpu idle 32, max 52
cores idle 20, max 41
cpu@3.7
cpu idle 33, max 54
cores idle 21, max 41
cpu@3.8
cpu idle 33, max 54
cores idle 21, max 42
cpu@ 3.3 (stock)
cpu idle 31, max 44
cpu@3.5
cpu idle 32, max 47
cpu@3.6
cpu idle 32, max 52
cpu@3.7
cpu idle 33, max 54
cpu@3.8
cpu idle 33, max 54
