$1100 system... Could You help Make this cheaper??!?!?
se1zure
~~~I am building a computer. Is there any way I could get pretty much these specs for around $850-$900? Like alternatives to parts. If somethign is overpriced, please tell me :). ~~~~
CONFIG:
LITE-ON 16X DVD±R DVD Burner W/ LightScribe and 5X DVD-RAM Write Black ATAPI/E-IDE Model SHM-165H6S - OEM
$31.99
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail
$30
ASUS ati Radeon x1950 pro
$184
XCLIO GOODPOWER 500W ATX 500W Power Supply - Retail
Model #: GOODPOWER 500W
$49.99
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
$240.00
ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail
$227.99
ntel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
$308
UBISOFT Ghost Recon Advanced Warfighter - OEM
FREE
Hitman - OEM
FREE
200gb internal MAXTOR
$20
Monitor (NOT INCLUDED IN PRICE) -
22in westinghouse for $200.
Total comes to about $1090 + Shipping
I think most of it is good, but if you could reccomend diff parts sto cut cost. I would really like ddr2800 ram, but i'm not sure if there is an equal quality to corsair.
My biggest concern is the video card. I know on evga you can swap up the card, but they only do nvidia. Is there an equal card for the same price in evga?
--- Where can I find an x1950 pro for a good price. I know this wiz site had it for like $16-, but hey are Sold Out :(
THANKS! All help appriciated :D
For the ram you can get some G.skill 2gig DDR800 for $209 and you could always downgrade the processor to an e6400 for around $220. Unless you really need the 2 pci-x16 slots and the wifi there's no point in going for that motherboard below are some other options from Asus if you really wanted to get and some others:
$180 - Asus p5b deluxe 2 pci-x16 no wifi http://www.newegg.com/Product/Product.asp?Item=N82E16813131045
$135 - Asus p5b 1 pci-x16 http://www.newegg.com/Product/Product.asp?Item=N82E16813131030
$145 - Gigabyte GA-965G-DS3 (great overclocker) http://www.newegg.com/Product/Product.asp?Item=N82E16813128018
$116 - Gigabyte GA-965P-S3 http://www.newegg.com/Product/Product.asp?Item=N82E16813128017
so you should be able to easily cut some costs :)
<edit> the x1950pro is a good choice and $184 looks like a good deal :)
http://www.newegg.com/Product/Product.asp?Item=N82E16827151136 replace your dvd drive with this one, same price but faster, unless you really want lightscribe or something
i would replace your mobo with this http://www.newegg.com/Product/Product.asp?Item=N82E16813131045 - asus p5b deluxe
or even with this http://www.newegg.com/Product/Product.asp?Item=N82E16813128017 -gigabyte GA-965P-S3
both great overclockers and quality boards, i dont see why people go for those really expensive asus boards (can anyone enlighten me? maybe im missing something and i would like to know if i am)
and i would replace your videocard with this http://www.newegg.com/Product/Product.asp?Item=N82E16814130064 but you probably want a stronger videocard so the one you picked is good. does anyone know if the videocard i posted is a good overclocker? maybe even having some unlockables?
this will bring down your price to about 800-900 and i think you will have only slightly less power (if that videocard is a good overclocker and has some good unlockables) hope someone can shed some light on the mobo and videocard
Why are you going with such an expensive mobo? Are you planning on goin crossfire? If not, go for a P965Express chipset. The 7900GT is about $205AR and performs on par with, and sometimes better than, the X1950Pro. G.Skill, Patriot, GeiL, etc are all good brands that are usually cheaper than Corsair XMS. XMS sticks are always overpriced, imo. I'd go for the G.Skills DDR2-800 for $210 instead, if I were on a tight budget. How far do you plan to OC? 400*9 = 3.6Ghz... well over a 1Ghz OC on an E6600. Most DDR2-667 sticks could reach 400Mhz as well, so you could possibly save some money there.
These g.skill sticks are on sale today, $200, 2GB DDR2-800, 4-4-4-12, 1.8v-2.5v:
http://www.newegg.com/Product/Product.asp?Item=N82E16820231087
i would also even suggest replacing your processor with the e6300. the extra cache on the e6600 adds a bit of power but otherwise you can overclock the e6300 to match it.
good luck
edit: the price on those g.skills that the guy above mentioned is really good although i dont know exactly how far they overclock
Any motherboard ou suggest I need to be CORE2QUAD aswell as core2duo :). Sli would be nice, and asus is the preffered brand. Wifi would also be nice :). A god FSB speed is also muy iimportante.I realize, that the 680i is good for these requirments, but a little steep.
Well, I picked the mobo mainly because it seems to be the best overclockker on the overclock database. Also, I need wifi, and the remote is pretty cool. I think it about balances out with a cheaper board, and wifi card, but i'll look into it.
Are you sure the g.skill ram is as good? The ratings on newegg can be decieving, but in this case, they look pretty bad.
And I want a pretty killer video card, and seeing as an 8800 is WAY outa my range, I think the x1950 is my best bet.
Thanks for the adive everyone! Do you have any more suggestions to cut costs, or in general.
Before I order tonight, I will post the final specs for review :).
Oh and:
"i would also even suggest replacing your processor with the e6300."
well, I'm o.c.ing on stock cooling, so there is no way to get a e6300 to 3.4ghz+ on stock, and even if i did, the 6600 has about a 10% performance boost because of the cache size. I have _no_ experience overclocking, and am worried I may mess something up trying to get an e6300 that high, wheras it's a 3 minute task to get the e6600 to 3.15ghz :)
