I can't find any manuals on this product or even this "AMP" manufacturer that makes it. I just moved into my new home and I have the below panel installed in my basement. Two of the wallplates (rec room & kitchen) have only rj45 network ports, while the other wallplates have rj11 voice jacks. I live with roomates in the house and we all use cell phones and will not be connecting a landline.
We want to replace the rj11 jacks with rj45 and just use this thing to distribute the comcast cable connection. I tried first hooking a computer in the rec room to the walljack and another in the kitchen I didn't even get a link light on either computer trying both patch & xover cables. I then brought out my cable tester which just read "VOLTS!" meaning it cannot test until voltage is removed from the line. I'm thinking its coming from the line-in cable pictured in the second image. Should I just rip this out?
Also is the correct way to wire this to hook the linksys router to the WAN IN jack? Thanks for any help someone can provide.
