Greetings.
Since the number of computers are expanding at my home, I want to reduce Wireless Connectivity and increase Ethernet connection between computers.
I will be running a Server that supports 10 TB Storage.
Will a Custom PC be better or should I use a NAS connected to a web server?
I currently use a Linksys WRT160n router that supports only 4 ethernet connections.
Now I need at least 40 Ethernet connections. Will a Switch do?
Also I will be running Asterisk to support Telephones.
My web server will not function globally. Only in LAN.
And also, the web server will have a 250gb Wikipedia Dump that will deploy 10 times; and also a lot of video from KhanAcademy for knowledge base.
I am looking for something powerful which will be quiet and have less downtime.
I have checked out Newegg, eRacks, and many other websites. But I am confused with what to consider buying.
Here is what I need:-
Any help or directions to the product to buy will be greatly appreciated.
Thank you.
- A Local Web Server or a custom built PC for 10tb hard drive suppoty.
- Router that can provide wired connection to about 40 users.
- A Terminal so I can monitor the bandwidth usage.
Thank you.
