I am planning on trying to fabricate my prototype of this case this year. I want to run it through some tests to see how the thermals work. I am also not sure about the final design, depends on if I put it into production and what methods are used. I will be trying for a 2+mm aluminum design. This case is designed around a 2x120mm AIO water cooler, but it would also work with an air cooler up to 65mm tall. SSD only, no optical although I might be able to change those options if produced.
