Wesley1357
- Jul 4, 2005
cpu companies once said that we would one day get to 10ghz. now we have stopped at 3.8ghz. what is the technical reason why we can't get more clock speed?
no. its not.Willseyvilleny said:think of it this way, my cpu is 5 ghx amd x2 2.5x2
yup. until they can fix transistor leakage, we wont hit insane clockspeeds with any conventinal CPU design. netburst has the potential, but current technologies in transistors are holding it back.heat.. heat.. and oh yeah, heat
hense my comment.Wesley1357 said:someone told me that thats a wrong analogy about 2 cores?
That's electrical current jumping outside of a predetermined pathway. It creates heat and- more importantly- electrical interference.Wesley1357 said:hey lithium726. "transistor leakage" is that heat or?
yep.Wesley1357 said:is that the reason having to do with all heat related problems, because of "electrical current jumping outside of a predetermined pathway", is this the explanation?
Wesley1357 said:cpu companies once said that we would one day get to 10ghz. now we have stopped at 3.8ghz. what is the technical reason why we can't get more clock speed?![]()
they consume more power as the transistors are further apart, which ramps up the heat too when you get to high clock speeds - transistors that are closer together can run faster than those that are further apart.Wesley1357 said:if making it smaller results in more heat! why not making the cpu bigger?
Also because having the transistors further apart allows more distance over which the traces can interfere with one another. Longer signal equals higher voltage, higher latencies, and higher noise or interference.lithium726 said:they consume more power as the transistors are further apart, which ramps up the heat too when you get to high clock speeds - transistors that are closer together can run faster than those that are further apart.
Asian Dub Foundation said:like 2 7800GTXs SLI dosent make 48 pipes
i'd bet not.Puterguru said:I'd bet they have pallets of 10 ghz's sitting around somewhere along with 9's and 8's and so on. The wonderful world of marketing however is going to make sure they get every single cent from us for every new 100mhz increment until they get to 10ghz.![]()
I was being a little sarcastic. My point is that if they could mass produce a 10ghz tomorrow that was affordable for everyone we would not see it for years. The big wigs that make all the money will milk us for every mhz/ghz increment they can get until we hit 10ghz.lithium726 said:i'd bet not.
the WR for a prescott is a little over 7ghz on some insane triple (or more) cascade cooling system - and you think intel has 10ghz chips just hangin around that can run on air cooling? i think not.
Puterguru said:I was being a little sarcastic. My point is that if they could mass produce a 10ghz tomorrow that was affordable for everyone we would not see it for years. The big wigs that make all the money will milk us for every mhz/ghz increment they can get until we hit 10ghz.
Zxcs said:Don't judge chips by ghz, instead by MFLOPS.
Reason? - Team Japan (and a few others) have hit over 7ghz with prescott and have realised that it is only slightly better than a dothan at 3.5ghz. The reason for this is because the CPU processes more in a single clock (someone help me out on the word for it, tired atm, begins with S). The future isn't how many ghz you can clock, its how many MFLOPs you can process.
