10GbE Performance = ~800-865MiB/s
war9200
Full thread here, started with 250MiB/s or so:
https://lkml.org/lkml/2011/2/5/159
Two SuperMicro motherboards.
Hi,
1. Defaults below:
sysctl -w net.core.wmem_max=131071
sysctl -w net.core.rmem_max=131071
sysctl -w net.core.wmem_default=118784
sysctl -w net.core.rmem_default=118784
sysctl -w net.core.optmem_max=20480
sysctl -w net.ipv4.igmp_max_memberships=20
sysctl -w net.ipv4.tcp_mem="379104 505472 758208"
sysctl -w net.ipv4.tcp_wmem="4096 16384 4194304"
sysctl -w net.ipv4.tcp_rmem="4096 87380 4194304"
sysctl -w net.ipv4.udp_mem="379104 505472 758208"
sysctl -w net.ipv4.udp_rmem_min=4096
sysctl -w net.ipv4.udp_wmem_min=4096
sysctl -w net.core.netdev_max_backlog=1024
2. Optimized settings, for > 800MiB/:
# for 3ware raid, use 16384 readahead, > 16384 readahead, no improvement
blockdev --setra 16384 /dev/sda
# not sure if this helps much
ethtool -K eth0 lro on
# seems to get performance > 600-700MiB/s faster
sysctl -w net.core.wmem_max=4194304
sysctl -w net.core.rmem_max=4194304
sysctl -w net.core.wmem_default=4194304
sysctl -w net.core.rmem_default=4194304
sysctl -w net.ipv4.tcp_mem="4194304 4194304 4194304"
sysctl -w net.ipv4.tcp_wmem="4194304 4194304 4194304"
sysctl -w net.ipv4.tcp_rmem="4194304 4194304 4194304"
sysctl -w net.ipv4.udp_mem="4194304 4194304 4194304"
sysctl -w net.core.netdev_max_backlog=1048576
# the main option that makes all of the difference, the golden option
# is the rszie and wsize of 1megabyte below:
10.0.1.4:/r1 /nfs/mru02/r1 nfs tcp,bg,rw,hard,intr,nolock,nfsvers=3,rsize=1048576,wsize=1048576 0 0
CPU utilization:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2069 root 20 0 18640 1304 688 R 91 0.0 0:15.50 cp
703 root 20 0 0 0 0 S 25 0.0 2:46.95 kswapd0
With a single copy I get roughly 700-800MiB/s:
Device eth0 [10.0.1.3] (1/1):
Incoming:
###################### #################### #### Curr: 808.71 MByte/s
###################### #################### #### Avg: 706.11 MByte/s
###################### #################### #### Min: 0.00 MByte/s
###################### #################### #### Max: 860.17 MByte/s
###################### #################### #### Ttl: 344.70 GByte
With two copies I get up to 830-850MiB/s:
Incoming:
############################################ #### Curr: 846.61 MByte/s
############################################ #### Avg: 683.14 MByte/s
############################################ #### Min: 0.00 MByte/s
############################################ #### Max: 860.17 MByte/s
############################################ #### Ttl: 305.71 GByte
Using a 4MiB r/w size with NFS improves performance to sustain > 750MiB/s
a little better I think:
10.0.1.4:/r1 /nfs/mru02/r1 nfs tcp,bg,rw,hard,intr,nolock,nfsvers=3,rsize=4194304,wsize=4194304 0
Anyhow, roughly 750-850MiB/s it would be nice to get 1Gbyte/sec but I guess
the kerrnel (or my HW, CPU not fast enough) is not there yet.
Justin.
So what NIC do you use?
Your link only says "NIC = 10GbE AT2 Server Adapter". Could you give us brand+type? Howmuch did you pay for the card?
I've been looking for the right moment to join 10GbE, but so far i found NICs to be around 600 euro and switches be about 1200 euro, which is too expensive i think. I would like NICs to be at 120 euro and switches at around 200 or so (8-port); though i probably join 10GbE before hitting these numbers.
That's the model...Intel AT2. I have a half dozen Intel 10gbit NICs sitting on my desk at the moment that I've been playing with. Guess I should post my results sometime soon. Teaming works too:
lol you DO know that guy's fooking nuts, right? Certifiably insane, IMO. The bastard actually has a crapload of 10GbE NIC and wants to run tests just for shits'n gigs and take pictures... NO... I'M NOT JOKING
Perhaps he's crazy enough to 'borrow' me one. :D
Either way, i would love to get 10GbE! But since switches are so expensive, how do you connect more than 2 computers in 10GbE environment? You can crosslink ofcourse, but with 3 PCs that would require dual-port adapters already. So we kind of need affordable switches as well.
FYI: i know the fibre/CX4 stuff is quite common, but i'm interested in 10GBaseT ("copper") standard, which should take over from the widely adopted 1000BaseT at some point.
Just to prove a point, 40gbit works too apparently. :p
LOL... the man buys 10GbE nic and tests them on a single CPU setup.... YA CHEAP BASTARD
the single socket Intel shit is probably faster anyways, lol (actually, i KNOW it is).
Amazing! How did you combine them? Also do you have a 10gbe switch?
Pretty much all Intel server NICs support teaming, so you just have to enable it in the software. I sold my last 10gbit switch back in 2008, so I've done all the testing with direct links.
Is that wireless 10 Gbps? I don't see any cables going to the network cards.... :D
hahahah
