ahlknysvgmwso
- Dec 23, 2005
Smoove910 said:Use a small flatblade screwdriver with a V knotch cut in it. Rest the "V" on the metal part of the spring retention mechanism and apply downward pressure. Never had a problem with the older heatsinks, never damaged any components doing so...
Good Luck!
Good Luck!
evilmonkey said:I've got a few socket A setups around still. Would someone care to explain in detail or spend 20 seconds in mspaint drawing how it's supposed to fit onto the heatsink clip?
