ive posted on other boards/forums and have received the utmost rudeness and unfriendly responses... i did a search and didnt find a quite similar thread so ... i come here to ask for help and not be shunned away.please bare with me..
I just installed my h50 on my 1090t last night. temps are around 28C at stock everything. i thought that it would be lower as i have a Haf 932. but whatever.. i ordered 2 GT AP-15's last night as well.
i have read of how great this chips are at Overclocking. I want the same results.
What i need guidance in is the voltages for the cpu, and the cpu/nb idk whats "safe" at a certain speed.
for example: one guy has his at 4.1Ghz with 1.45 volts (vcore). Too me this is too much. but i am retarded so i shouldn't speak...also he just oc'd the cpu bus to like 260mhz.
this is where i get confused even more. What should i use? the multiplier or the cpu bus? what about the the Hyper threading option? [ht] in the bios
i have an asus ma89gtd pro with 4gigs of mushkin ram rated 1600mhz. 7-9-7-24-1t. i have it at 7-8-70-20-1t. i can go lower. some people are running these at 7-8-7-15. long story short;great ram.
Conclusion: i have good hardware just no experience in overclocking smartly and effeciently
multiplier vs cpu bus?
voltages at what ghz is good? whats too much?
should i lower my ram speed but oc the cpu bus? or keep it at 1600 (or higher) with tight timings and just use the multiplier?
thx for the positive non-bashing replies. if some of u have this chip, what specs are u running at? thx
