if the pinsetup on your board differs from the one in the manual the board may have been made for an OEM company, ie Gateway, HP, etc. and they may have changed the pin configuration to the frontpanel connector of their specific case. remove the wires to your front panel and try shorting them in pairs first the two power pins shown in the manual if it starts when shorting those get a new power button for your case. If it doesnt start with those try other pin pairs until the board starts if no pinpair starts the computer then the Motherboard is dead.
I have never seen it wreck a board either it 'closes' a circuit or it doesn't and yes it could also be the CPU but if the processor was a working pull and was stored properly it should still work years later. Could also be problems with the powersupply test it on another board you know works
try the supply @ 110 on the board if ya fried the board or powersupply won't hurt it worse lol if it boots up then no harm no foul.
