1080p MKV @ high bitrate possible?
Tomson
..with a mini itx pc?
i'm not all that up to date with sff but I wondered if a mini-itx solution would be possible for high bite rate 1080p mkv's
thanks in advance.
yes. intel has a g45 or something along those lines itx mobo coming out son w onboard hdmi and full bluray codec support. I don't know the model # but I saw it in a thread earlier...
As always, thanks for the responses, I know I could have used the search a bit better but I wanted a more direct answer regarding these high bitrate mkv's.
Thanks wiretap, your thread was just what I needed. I was a little surprised that the 4800 am2 would be ok but it looks fine, the only one was hellboy but that then I never encode to anything past 12mb/s if I can avoid it.
Yeah, that Hellboy encode peaks around 40mbit, lol. It's pretty intense.
I think my encode of eyes wide shut was around 15mbit, that's the highest I've seen.
Would a 6000+ be possible inside one of those cases? I'll have a check on the net to see if the wattage varies across the am2 range.
I'm thinking of a jetway coupled with a 1.5tb Seagate at the moment
I didn't get that one because I don't think 8ch audio works with LPCM over HDMI.
The realtek chip it uses is six channel only and can support DTS Connect if the manufacture implements it which I don't think Jetway has.
