If you're not overclocking, it's probably not worth upgrading from a 940. Now, if you crank it up to ≥ 3.5 GHz, it probably is, if the tasks you do can utilize more than four threads, or if you like to run several CPU-intensive tasks at the same time.
Ok, I currently have a x2 555 @ 3.8ghz and a GTX 470. My lowly AM3 motherboard is limited to 95w CPUs.
For a computer used mostly for gaming and media consumption would the 1045T be a an upgrade, side-grade, or massive downgrade?
A 965 is a 125W cpu and will not work properly or at all on a 95W board.
A 1045T will and would be a big upgrade from an X2, even though the 1045T is clocked slower.
The OS and lots of programs/games will use more than 2 cores.
I'd guess you can probably undervolt the 965.....no?
