103cfm fan but want controller
automaton
I bought a high cfm for rear of my storm enforcer now I want to put a fan controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118217
the specs say 11v does that mean it wont operate as fast as 12v
Output Voltage: 5V - 11V +/- 2% Allowable Power: 6W or lower Fan controller for adjusting the fan speed of a single fan according to user preference.
also Do not use FAN MATE 2 with fans that have a start up voltage of more than 5V. Please check the start up voltage in the specifications of the fan.
how do I find out if this fan will work?
chances are a 103cfm fan pulls WAY more than 6w.
This.
You should list the fan and specs for anyone to know a good controller to use, most fans that "really" push 100+ CFM pull allot of power and will burn out most controllers, as its not good to run them close to max all the time, they tend to have really short life times even if it's within the power draw range.
