i have a little pci slot blower that sits there and blows air over the ram. i just took off the metal mounting bracket, it works pretty well.. though if you don't go over 2.8v, you probably won't need active cooling. i do in my case cause there's next to no airflow in the cpu area due to there being a waterblock and not a hsf.heliotrope said:Eclipse, do you actively cool the RAM in your computer?
hehe, yeah.. that's the stuff, though it's still linked in the first paragraph of the first postUnknown-One said:That must have looked realy stupidI posted the wrong link! it should have been:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146545
I fixed my first post, now, is THAT the same ram for about $12 less?
hehe, might as well see how it does. technically your ram should do better than mine, as it's the same chips, but single sided.. single sided dimms almost always overclock better.Brando457 said:hmm and i thought having my cpu at 2.7 ghz and ram running at 200 mhz with timing of 2.5 - 3- 3- 8 was good
I might have to change them to 3-3-3-8 and go for 250 mhz whtcha think eclipse
(cf)Eclipse said:thanks, and most likely.. at these speed ranges, it's almost always ram limitation, not memory controller![]()
yup, though 250mhz at 3-3-3 is roughly the same latency as 203mhz at 2.5-2-2.. and a lot more bandwidthn64man120 said:Correct me if I'm wrong Eclipse... but doesn't dividers mean so little you shouldn't look at them at all and focus more on getting tight timings and such instead?
i'll be looking forward to it. also, don't forget to post your results in my 1gb oc'ing thead.. enjoy made one over at XS tooburningrave101 said:I just ordered two sticks of the Crucial Value a little while ago. I'll see how well they overclock in dual channel mode on my DFI NF4 Ultra-D.
i'd appreciate it if you post your results here:MemberSince said:I also am waiting on 2 of these Value- dimms from the egg, After being alerted by an AT member.
I will be using them in a nf 3 Ultra-D and shall report back for any one interested.
yeah, it should be fine. i did some testing before without a fan and only really lost ~5mhz from top speed.. didn't do extensive testing so i'm not 100% on itheliotrope said:Do you Crucial Value 1gb-stick-owners think that they would be overclockable much without the cooling of a fan blowing directly on them?
I've got a Shuttle system, and it wouldn't really want to mount jury-rig a fan in there for my RAM if I can help it.
(cf)Eclipse said:yeah, it should be fine. i did some testing before without a fan and only really lost ~5mhz from top speed.. didn't do extensive testing so i'm not 100% on it
there's a lot of things i should get.. another stick of this, an FX-57, a 7800gtx, a sata dvd burner, ect ectburningrave101 said:You should buy another stick so that you'll have 2GB of RAM like the rest of us and so you can do more testing.
(cf)Eclipse said:there's a lot of things i should get.. another stick of this, an FX-57, a 7800gtx, a sata dvd burner, ect ect![]()
Swishbish33 said:Good luck burning, looking forward to your results.
burningrave101 said:Bah, you just need another 1024MB stick of Crucial Value RAM, not all that other junk.
BTW, my two sticks came from Newegg today so i'm going to test them out a little tonight and i'll report in on how they do.
Oh good, now I dont feel so bad about my board being locked at 2.6v vRAMburningrave101 said:I have my best luck with 2.6-2.7V.
that's what happened to me at first.. mine liked a bit more at first, 2.8v.. i used it for a couple of days and tried again, 3.1v definitly got me somewhereburningrave101 said:And one thing i would like to comment on about these chips on the Value sticks is that they do not like voltage at all. I tried 2.9V and i just got thousands of errors. I have my best luck with 2.6-2.7V.
