100Base-FX Validation/Verificaiton
Discussion in 'Networking & Security' started by Trepidati0n, May 1, 2015.
  1. Trepidati0n
    Trepidati0n [H]ardForum Junkie
    8,875
    Oct 26, 2004
    Unfortunately, most scopes and packages associated with them only verify/validate copper based Ethernet. This means they don't really know how to "understand" NRZI vs the usual MLT-3 at the physical coding sublayer (PCS) for 100Base Ethernet.
    However, good news is that I can pretty much, we decent confidence, reduce the test to "did the packet make it there" and corroborate on the scope via the eye diagram.
    So, here is the question: Is there any freeware or low cost application that will allow me to transmit a semi-generic Ethernet packet/frame from one PC to another PC indefinitely and indicate to me if the packet was "lost"? At the end, I just want a report that says "I sent x million packets with y bits and x packets were lost".
  2. -Dragon-
    -Dragon- 2[H]4U
    2,318
    Apr 6, 2007
  3. Trepidati0n
    8,875
    Oct 26, 2004
    ping it "should" work, but always looking for alternatives that might offer a bit more knowledge/insight. Part of the reason I'm shying away from ping is the packet is a little too rigid. Some of the more expensive tools send a bit more "randomish" data. Also, ping isn't very time efficient. I would hope a focused program could send more bits/second.
  4. green91
    green91 Limp Gawd
    398
    Sep 2, 2012
    Look up perfSONAR.
