$1000 Mini ITX Machine.
pwnrhasta
Gaming mostly. Mechwarrior Online, League of Legends, CS:GO. Battlefield 3.
$1000, yes.
Torrance, California, 90505
Case, PSU, CPU, GPU, RAM, HDD or SSD, DVD Drive, Motherboard.
None.
6) Will you be overclocking?
Yes.
1920 x 1080. 23inch
Soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Preferably a motherboard with WiFi.
Yes 64bit.
Also I like this case a lot, so it would be nice if I can get it in the build.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112265
And if it is possible to fit a SSD in the build, that would be nice.
