Hey [H] been awhile since I've upgraded my PC and I'm a bit out of the loop but I think it's time for a new PC altogether. I was wondering if some of you maybe be able to check out what I've come up with for a sub $1000 gaming PC, I'll post the link to my pcpartpicker after the questionnaire.
Gaming, Photoshop mainly. Working as a software developer also, so CPU power is important
<$1000 tax and shipping included without cooling as I may go with a watercooling setup
USA, Indiana
Case
CPU
Mobo
GPU
SSD ~ 128-256gb
HDD 1 or 2 TB
PSU
RAM
CPU Cooler
Windows 8
I have a 550W Corsair PSU, I also have a Q6600 but don't know if it'd be worth it anymore as LGA775 socket
6) Will you be overclocking?
Possibly depends on if I go watercooling or not
1900x1200 27"
July or August 2014
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0
SATA 6.0Gb/s
Onboard video is not needed
I need a new copy of Windows 8, but I may be able to get this cheaper through my University
And here is what I have come up with:
http://pcpartpicker.com/user/wr3tched/saved/4HDR
I 100% want a mATX system to use with the Silverstone TJ08-e case. Other than that thanks in advance!!
USA, Indiana
Case
CPU
Mobo
GPU
SSD ~ 128-256gb
HDD 1 or 2 TB
PSU
RAM
CPU Cooler
Windows 8
1900x1200 27"
July or August 2014
USB 3.0
SATA 6.0Gb/s
