1000 dollar gaming computer please help.
BBruins
Gaming primarily, word processing, email. I want to play the current FPS and upcoming games. WOW, starcraft2.
800 to 1000
3) Where do you live?
MN
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except keyboard, mouse, speakers and monitor. Ill need os.
None
6) Will you be overclocking?
Eventually.
24 inch lcd
Ill order it tomorrow if I can.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing out of the ordinary
10) Do you already have a legit and reusable/transferable OS key/license? No.
THanks,
If you are a Newegg e-mail member you can get that Seagate harddrive for $49.99.
I ordered my system but I think I screwed up. I ordered the 32 bit oem windows 7 instead of the 64 bit by accident.
I want the 64 bit for games right?
Im running 4 gigs of ram.
BBruins.
If its just 4gb eithor could be used, you may be able to download an iso off the net and install using your key, too.
What games do you play? If FPS/fast action games, I'd suggest at least an HD5850, which tends to be faster by around 15% or more at your high res.
