$1000 - $1100 SFF System
blisstik
What do you guys think of this setup? What other recommendations can you make? Anything better than the E207WFP within the same price range?
Shuttle SN68PTG5 $260
http://www.newegg.com/Product/Product.aspx?Item=N82E16856101040
AMD 5000+ BE $095
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103194
Patriot 2GB Ram $073
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144
Patriot 4GB Ram $128 (+55 from the 2GB AND -$42 REBATE)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220269
Seagate 500GB $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148136
Sony NEC DVD+R DL $028
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118002
Logitech Keyboard $008
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126013
Logitech MX518 Mouse $040
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
NOTE:
1. Shuttle has onboard VGA and HDMI, upgrade later if gaming is desired. The onboard will not be enough for today's games, it should be OK on COD4 at lowest settings.
2. Don't cheap out on other brands of RAM, I selected the one's with the lowest latency = better performance for your video editing needs. Future proof on RAM for $59.25 more. 2GB is getting OLD!
NEWEGG TOTAL 2GB SETUP = $614 + 47.59 (7.75% tax) = $661.59 + SHIPPING
NEWEGG TOTAL 4GB SETUP = $669 + 51.84 (7.75% tax) = $720.84 + SHIPPING
DELL E207WFP Monitor $274 SHIPPED
http://cgi.ebay.com/DELL-Bran-NEW-2...-warranty_W0QQitemZ270192044812QQcmdZViewItem
Recommended Monitor:
http://www.fotoconnection.com/p5921...07wfp-201-inch-widescreen-flat-panel-lcd.html
The 2007WFP is the same size but more expensive, why? It uses different technology (PVA) and produces better color and sharper images than all other cheap brands. This is better than the E207WFP which usese a different panel technology. If you got the money, go for this monitor. I've had my 2005WFP since Half Life 2 came out, no problems, ever!
ok... intel is really the way to go at the moment, but if you do prefer the amd stuff i guess that's a good shuttle system and cpu to go with...
e2160 for $50 at tigerdirect isnt bad.
$175 shuttle sd30g2
$225 sg31g2
uhh that's a weird ram setup for me... 6gb? i've got 2x2gb of crucial value ddr2 667 D9FTB. found them for $20 each stick after mir. they are going for about $60 for 2 right now, but if you can wait for a good deal then you could get some... if you like lower latencies, i use these at 4-3-3-5 on my ga-g33m-ds2r (the mobo won't let me get cas down into the 3, and 4-2-2-5 just reverts back to 4-3-3-5) D9ftb's supposedly scale well with voltage and can get to 900+ /w tight timings.
i don't know what chips the patriots use, but if you're only doing light oc'n they should be fine.
7200.10... for $9 more you can get a 7200.11 supposed to be faster, quieter...
24" lcd pva monitor $349
I did a sg31g2 with an e8400 and a 9600gt, 320g hd, 4gb ram for less than $1k. Pretty sweet system if you ask me. Even threw in blu-ray and still made under budget.
edit did not know (poor reading comp) you wanted a monitor and input devices..still i am happy with what i got so you may consider...
