$100 Naked Computer?
Sunin
[H]ard|DCer of the Month - August 2008
http://www.clubit.com/product_detail.cfm?itemno=A4842001#
Mobo/CPU/Vid = 59.99
I was curious, this is serious low wattage so a small PSU = $15
memory = $20
Run it with out HD... CD based...
Wonder how it would do PPD wise...
You could even get a 430watt antec and run probably 4 of these off the one PSU with out much issue...
Just curious what it would produce.. :) hehehe
The Intel® Desktop Board D201GLY is an innovative solution for the sub-value market segment. With an Intel® Celeron® processor and graphics integrated on the board, this board enables easy system integration and helps you to achieve a lower system cost. This board has 10/100 LAN and can support up to six Hi-Speed USB 2.0 ports, providing both connectivity and ease of use for your computing needs such as email and Internet access, instant messaging and Voice Over IP (VoIP).
The Intel Desktop Board D201GLY is built in smaller uATX-Compatible form factor providing lower power consumption and low sound emission.
Here is a link:
http://www.intel.com/products/motherboard/D201GLY/index.htm
:eek:These things fold like Sh#T, I had a chance to try a couple out.
So I decided to fold on one, just to see. The WU it picked up was worth
15 points at about 24min/frame. I didnt bother after the 1st WU was done.
