turn off the pc? blasphemy!
like the 2nd poster said, its all about balance between dust protection and airflow. you are gonna have to do some maintenance once in a while, there is no way around it...
Although it's not exactly attractive, I've found that keeping a plastic trash bag over my pc while it's turned off also really helps. They make special custom fit bags that essentially do the same thing but I haven't found enough cause to purchase one.
You can make one.
Here's what I did :
That's a completely passive rig.
It's basically an 18" square 'environmental' electrical enclosure......the heat producing components all have direct thermal paths to the case.
Now , it won't tolerate folding , but for basic daily use it works just fine.
I am not finished with the thermal paths and/or sealing , but when it's finished , the case will actually be gastight.
You can make one.
Here's what I did :
http://braineater.kicks-ass.tv/miscshite/tt2_313.jpg
Yep....Mines actually for use in an explosive(flammable) atmosphere.It'll be filled with pressurized nitrogen.
I might actually throw it in the garden and get a pic of it running while I water it tho , just for kicks.....
Edit :
Here's a better shot of the CPU-case thermal path....
*snip*
The process carries on from there....
How would I go about 100% dust proofing a case?
Is there some case out there that is designed to be truly dust proof?
Also, how do you dust-proof without reducing airflow?
If he wants 100% dust proofing, why would you give answers that will still allow dust in his case? Filters won't cut it. He needs an enclosed NEMA rated dust proof case. Some things come with cost. If he doesn't want 100% dust proofing, he can save a lot of cost. But, he never gave us the application he's using it in, so I wouldn't recommend anything else that lets even a little bit of dust inside. I believe he said 100% dust proof for a reason. It could be for a harsh environment application.
Instead of focusing on the computer case, you should focus on the room. If the room/house is dust-free, so is your computer.![]()
