$100 dollar budget for PSU.
AdamMT1618
With a $100 budget, I need a good power supply to handle my rig. I know there is a recommendation sticky above, but I am still left unsure which is the best to get. I need performance, not lock ups and I want the most for my dollar.
Here is my stats:
AMD Athlon 64 3500 90nm Winchester
MSI Neo2 Platinum
BFG GeForce 6800 GT OC
NEC DVD+RW 16X 3500
1 200 Gig Seagate Barracuda HD 7200 RPM SATA
1 3-1/2 inch floppy
2 120mm fans
1 card fan
I am currently using an Aspire 520Watt PSU 34a 12v, but my PC is locking up about every 2 hours and I can not figure out why. I think my only other option is to replace the PSU and see if that fixes my problem.
Please, any suggestions would be appreciated. I heard of other people using my current PSU with there systems with no problems, but I don't know what else to do.
Thank you.
Might not necessarily be the power supply itself, but the power coming into your house. Do you get a lot of brownouts there? Girlfriend turns on the coffee maker and microwave and suddenly the computer locks up? :p Something to think about.
Sparkle Power 550W Power Supply good? Only $99.00 at Newegg, I can not really afford anything higher. To bad it does not have LED's.
MODEL "FSP550-60PLG" -OEM
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-478&depa=0
MTBF: 100K hours at 25ºC
Approvals: UL 1950, CSA C22.2 Level 3, TUV EN60950, NEMKO EN60950 (CB Report),CE
PFC: Active
$99.00 + 6.99 Shipping
Antec 550W Power Supply, Model "TRUE550" -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-910&depa=0
Output: +3.3V@32A; +5V@40A; -5V@0.5A; +12V@24A; -12V@1A; +5VSB@2A
MTBF: 80,000 hrs. @ 25ºC
Approvals: UL, TUV, CB, VDE
PFC: No
$96.99 + $6.99
Antec 550 Watt Power Supply With 2 Fans 5.25 Control Panel, Model "TRUE CONTROL 550W" -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-922&depa=0
Input Current: 10A@115VAC; 6A@230VAC
MTBF: 80,000 hrs. @ 25°C
Approvals: UL, TUV, CB, VDE, F
PFC: No
$100.50 + $6.99
Fortron 530W Power Supply, Model "FSP530-60GNA" -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=17-104-968&depa=0
Input Current: 12A/7A
Output: +3.3V@30/17A,+5V@44/24A,-5V@0.3A,+12V@16/28A,-12@0.8A,+5VSB@2A
Approvals: UL, CSA level 6, TUV, NEMKO, FCC, C-TICK, CB, CE
PFC: No
$75.50 + $6.99
Or something different?.
I gimped on buying that Aspire 520watt PSU, maybe there is nothing wrong with it, but I need a new PSU before I can rule out my problem is a defective video card.
Thank you.
I'd go with that Sparkle 550W, its a solid PSU for very little money (relatively speaking). I don't think it is ATX 2.0 compliant though...
I just got a CoolerMaster RealPower 450 watt PSU and it works great.
It's silent and delivers perfect power. u dont need a 550w psu for what u've got. 450 is just fine.
also, the coolermaster has blue LEDs in the 120mm fan, has an active PFC, and comes with a motherboard adapter. has alot of features for only 80 bucks on newegg.
i would highly recommend the RealPower PSU.......i just got an Antec Solution SLK3700-BQE and it's so amazingly quiet even with a front 120mm fan added.
i've got a fortron 550 (same thing as sparkle), and i love it.
It doesn't come with the adapter, but you don't need it, the plug fits on the 20pin boards just fine (as long as there is nothing in the way)
