I built a new pc recently, here are the following specs:
E6600
2GB DDR2-900
EVGA 680i
EVGA 8800GTX
Now for my hard drive, newegg made a mistake and sent me the IDE version of the Seagate 7200.10's that I ordered, so I sent them back and the SATA drives should be here soon. Until then I wanted to test out my system using my old IDE drive, which is a 120GB IBM Deskstar.
I knew something was up when it took just as long to do things as my old computer did. I made a MAJOR jump from the old computer to the new computer, but ripping and decompressing files still takes as long as it used to. Just to give you a clue of the comparisons between systems, the old setup was:
Pentium 2 400mhz (thats right, 400)
384mb ram
gateway motherboard
Radeon 9500pro video card (kept getting agp cards from friends that moved on to pcix)
I looked in the system monitor that nvidia provides and it shows that cpu usage and memory usage are quite low, even when the system is bogged down, but that disk usage is 100%....what causes this? Is my old hard drive that old? I bought it in 2003....
E6600
2GB DDR2-900
EVGA 680i
EVGA 8800GTX
384mb ram
gateway motherboard
