I'm working on a laptop... It is a Gateway 4028GZ and here is the problem: I have basically 24hrs to figure it out. Basically none of the network related hardware will work. The built in Wifi, NIC, and even a PCMCIA wireless card. What happens is, all of the drivers install fine (yes I have downloaded the latest drivers and reinstalled them many times!). But after they install they are listed in the device manager under the "Other" category. They all have a yellow ! next to them, and when I double click to check the status of any of them, they say "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)". I recently reinstalled the network components and ran the netsh ip and winsock commands. When I hook it up to my router it pops up and detects a LAN connection, followed by detecting my router, and then an internet connection (all these are displayed). It can access the internet, but still says that there is a conflict in device manager. I bought and installed a Netgear PCMCIA Wireless G card and it does the same. Driver installs, but then has yellow ! mark in dev man and netgear connection software will not run!
Any ideas!!????!?!?!?!?!? I will pay whoever finds a solution if needed!
