- Jun 29, 2004
http://www.newegg.com/app/viewproductdesc.asp?description=11-117-035&DEPA=1
not too bad.
:edit: OK with S&H its a 25 dolla case
not too bad.
ozziegn said:ice cold compared to the ebuyer cases that can easily be had for under $13 delivered...
twyztyr said:The difference is that the Skyhawk is a clean case, doesn't have that big weird Mercedes emblem on the front...some people like a clean and simple case, which the Ebuyer cases are not.
Before you bitch at me for contradicting your point of view, I bought the silver case from Ebuyer, and recieved it yesterday. The chassis is a bit weak, and the mobo tray isn't removable (which will be rectified soon), but the side panels and top are surprisingly well built.
I got the black one.. and yes, it sucks balls...Laforge said:Again,
I'll mention
EBUYER has more cases, for less money.
Ebuyer KG-201 Beige Case Only - Front USB/Audio Ports - No P/S 145932 $5.84 -
Ebuyer KG-188 Grey Case Only - Front USB/Audio Ports - No P/S 145931 $6.89 -
Ebuyer KG-318 Black Case Only - Front USB/Audio Ports - No P/s 145927 $5.86 - Ebuyer KG-318 Silver Case Only - Front USB/Audio Ports - No P/S 145924 $6.70 -
Shipping charges tend to be around $7 to $8
Take this from a guy who recently got called a "newegg !!!!!!" - Your case is *NOT* a hotdeal.
I mean, for $6.30 more, AT newegg, you can get a case, delivered, that has a 400w psu
Laforge said:Actually, I put 90 lbs on top of the grey "mercedes" case and it had no problem supporting that.
twyztyr said:Before you bitch at me for contradicting your point of view, I bought the silver case from Ebuyer, and recieved it yesterday. The chassis is a bit weak, and the mobo tray isn't removable (which will be rectified soon), but the side panels and top are surprisingly well built.
ozziegn said:let me remind you once again at what you or me or everyone else pays (or paid) for them cheap cases at ebuyer: little to next to nothing.
heck, I dont give a hoot if the darn cases have umpteen sharp edges, no removable mobo tray or if it sways in 100MPH winds or higher. all I care about is if it does its job and that is to house all of the internal parts that make up a computer system and of course these cases do that job so there's ZERO room to complain about them IMO.
but then again, I'm sure that there'd still be someone who'd complain about these cases even if they were 100% free including shipping. there'd still be some joker out there who'd compain so whats the use...
