QuadDragon
- Jun 26, 2007
Anyone know of a company thats working on a 10.5 inch 5970? I'm replacing 2 ati 4870 x2s but my case will only hold a 10.5 inch card.
doubt you will see one at 10.5 inches since the 5970 needs every bit of the current card size to run.. if anything they will probably get larger as they try to stuff as much memory on them as possible for the 4GB versions..
The HD5970 is the ATX standard for a full length PCIe expansion card which is 12.25 inches. I don't believe they will try and make any further cards larger than this since this is the largest standard size. If anything, more complex cards will implement more layers for their circuit boards to accomodate more complexity. AMD and Nvidia will try to adhere to the standard to avoid backlash from case manufacturers. Until this point, it was the case manufacturers that chose to adhere to the standard or not. I wouldn't expect any larger cards than the HD5970 until the PCI SIG standards group approves a larger size.This is a dual GPU card it needs a lot of space, the reference size is a hair over 12" i think, I highly doubt you're going to see a 2" shrink. You be better of investing in a bigger case, or some dremel kit![]()
