Apr 5, 2004 #1 B bobsaget Supreme [H]ardness Joined Jan 24, 2004 Messages 4,403 I ran 3DMark2001(not SE, will this make a diff?) and got a score of 10,070. Is that about right? Will more RAM help it any? Thanks
Apr 5, 2004 #2 S Spleeze Limp Gawd Joined Oct 15, 2003 Messages 433 Dude, Post your computer's specs.
Apr 5, 2004 #3 B bobsaget Supreme [H]ardness Joined Jan 24, 2004 Messages 4,403 Originally posted by Spleeze Dude, Post your computer's specs. Click to expand... Yeah, just put them in the sig, sorry! (I had them in there, I recently deleted them, and forgot they weren't there.)
Apr 5, 2004 #4 T ThisMonsterLives [H]ard|Gawd Joined Oct 9, 2003 Messages 1,307 more ram wouldn't help that score a bit but it would be good for games which is what is important unlike 3DMark
Apr 5, 2004 #5 T tracerwilly Limp Gawd Joined Jan 15, 2004 Messages 136 that seems low...check you sig against mine. i get over 14k. is your xt overclocked
Apr 5, 2004 #6 V V0ltage [H]ard|Gawd Joined Feb 7, 2004 Messages 1,231 thats really low, download 2001SE and run that. your system should be getting 12k at least.
Apr 5, 2004 #7 V vanquished Limp Gawd Joined Oct 29, 2002 Messages 359 Yeh, that is a bit low. My rig is basically the same as yours, except for the graphic card and i get 12.5k. Check you settings in the Nvidia drivers cause they make a hell of a difference
Apr 5, 2004 #8 B bobsaget Supreme [H]ardness Joined Jan 24, 2004 Messages 4,403 Alright thanks guys! Since my score might be about 1000 to 1500 points lower than what it should be, what should I do first, and how do I do it? thanks
Apr 5, 2004 #9 C chuckm1020 [H]ard|Gawd Joined Jun 12, 2003 Messages 1,175 go to www.futuremark.com and download 3dmark01se. then make sure that aa and af are completely off. then give it a go
