1 or 2 Radiators
James24
I am running my water cooling system with a dual 80mm radiator. I have it set up in this order, Pump, CPU, GPU, Radiato, Resevoir. I was thinking of adding a second radiator between the CPU and GPU. How much of a difference will this make? I have a 12v pump thats says it has a 1 meter head and pushed 550 l/h, http://pcwatercoolingshop.netfirms....id=40&osCsid=7934038d16a378493741643c1ebfa79f
Will I need a better pump to do this?
Also, The radiotor I do have is mounted flat on the bottom of my case with the fans pushing air from the case through the radiotor and out the bottom. Should I reverse the air flow? Thanks for the help and I appoligize if this is already posted.
