+1 9800GTX for SETI
xdivenx
I was tired of getting eue's with Folding@Home, so tonight I just finished downloading and setting up Boinc to use my 9800GTX. 89% percent done with my first unit. Feels good.
I joined the HardOCP team! Anyone on that team active over here?
Welcome to the team xdrivenx! Thanks for joining the party! :)
If you get bored, check out the DC Vault thread for a wealth of BOINC knowledge on lots of different BOINC projects (including SETI). If you have any questions just ask. Good to have you aboard!
Razor, I think you picked up another Commando ;)
Well we could use some help to be honest.
Currently there are so many projects it is hard to cover them all with the current ranks of the commandos and we are trying to break into the top 10 in the DC-Vault, we are so close and every little bit helps.
Thanks for your contributions xdivenx (DivineX), we are very glad to have your help.
I read a guide online and already the lunatics unified installer for Cuda. Anything else I should do?
Im at 187 units as of this monring :)
Looks like your up and running strong.
If you have any idle CPU cores, there are many Boinc projects that we are working on to further our position in the DC-Vault.
Thanks for your contributions DivineX.
Tell me where to join next. I was looking at joining the Dynaping project, but I wasn't impressed by one of the admin's attitudes there. Is there another place you wanted some help at?
I wouldn't mind putting some of my 64x2 @3Ghz to work.
I hopped on Cosmology, only 10 active members there. Thanks for the suggestions.
PS. Also adding a 9600GT mobile and my C2D.
Excelent !
We defiantly need the help in Cosmo and the 9600GT will add all that much more fire power to our team.
Thanks for helping us go after the top ten spot in the DC-Vault.:D
