1.65 on 2.8C too much?
jagzzzzzz
I have a sl6wt 2.8C Northwood and was wondering if 1.65V is too much. I am running it on a max3 with gskill 4400 LE's 1GB. Any advice on the subject would be appreciated! I want to keep it at 1:1 and try to hit a 250 FSB, right now the best I can do is 230 FSB at 1:1.
Dont worry about keeping it at 1:1, change to 5:4 and see how high you can get. if you get an extra 20FSB, it will easily compensate for the ratio. Then benchmark both ways. Trust me most people have much better benchmarks and performance by using a ratio, get a higher FSB/ CPU clock and using tighter timings also.
I use the 3:2 ratio to get to 300FSB, and my ram scores are 6000Mb/s at that, with ram at only DDR400 2-3-2-6
Ratio's are your friend, trust me dont be scared of them!! (at least on Intel mobos)
Ex:
P.S. 1.65 is probably not too much b/c Abits usually volts about .05 lower than they read in the BIOS. so 1.65 is probably only 1.60v
Tried the 5:4 timings, nothing too much better. It still wouldn't boot to windows @250 and I tried a lot of variations. I am going to keep working on it, but it's not looking good. I think 3.5 is too high for my cpu. I have noticed my psu voltages floating around (TT420) could that be a problem? Also would adding AS5 to my NB help much with it? I am on air, are you cooling with water. All other opinions are welcome as well.
I can now get into windows and surf with it at 250, but when starting any intensive cpu operations like sandra, it reboots. Is there hope for me to yet get this thing stable? Please help! Everybody!
Did you try 240, 245, etc... and work gradually up. I go up in 5Mhz increments until I hit instability. Then try a few different tweaks like loosening timings on ram, etc... to make sure its not ram (even try 3:2 ratio for shits & giggles), if it still fails, I go down 3Mhz, test, then work back up 1Mhz at a time. To find the max OC. Then if Im really close to a round # like say I'm 3.41 or 3.46Ghz, I'll back off one 1 more FSB to a nice round 3.400Ghz or 3.450Ghz etc..
I'm on air, but my chip does about 3.4Ghz on default voltage (which is really undervolted at like 1.48) It takes 1.6v in BIOS, but actually reads 1.55v in windows to hit 3.6Ghz and 1.625 for about 3.66-3.7 but motherboard gets flaky over 300 FSB. I just happened to have one sweet chip. LUCK OF THE DRAW.
Though, I really think any recent (especially OEM chips) 2.8C's are speed binned b/c they didnt make the cut at the higher Ghz, like 3.2C or 3.4C. Back in the day of the 2.4C's there was such a demand for the 2.4C, I think a lot of highend chips that could have been 3.2C's etc... got binned down for no reason.
My 12v rail was always low (& fluctuating) when I checked voltages, back when I was only using a 300W PSU for the 3.6Ghz OC. But it didnt really seem to affect stability.
Meaning that you wont be able to hit 3.2Ghz or 3.4Ghz at default voltage with a standard cooler like a 3.2C or 3.4C can.
It means to overclock you'll need a bump in voltage, better cooling and your chip still might not even be capable of the higher speeds.
IE: = they're slow chips that could be used for anything else but 2.8C's
So 3.4 or 3.5 on this chip would be a good overclock. I am planning on putting some AS5 on my northbridge, so that may help me reach it.
Simply adding AS5 to your NB isn't going to make a whole lot of difference....I know...I tried it...alone it's not enough.
3.5GHz or so is a decent OC for a 2.8C.....gets you to 250fsb to run 1:1 with some PC4000 anyways. My 2.8C made it up to 3.9GHz on water with about 1.9v and ran like that for quite some time....so dont let ppl tell you that over 1.75v is dangerous and fatal.....SNIDS hasn't been around for some time.
So your saying even at 1.75 I'll be ok? I like most don't want to everyday OC and use at my max, but I do want to know what my max is. What type of water cooling are you running? I was thinking of the koolance water cooling rig on newegg, but am unsure if it's going to allow me to cool a whole lot more.
I was running a custom built system using a DangerDen TDX block, and a DTek Pro Heatercore.....worked great. 1.75v is fine for teh CHIP....but depending on your cooling you may or may not have to stop sooner. Even though the cpu is fine at 1.75v and higher, I'm not gonna tell someone using the stock intel cooler that they can run their chip at 1.9v and not worry.
Basically....dont worry about the voltage, just watch your load temps as you start to feed the chip more power...and once your load (on air) starts hitting 60C I'd stop....if you're on water it's your call....but as long as you're fairly stable at each new clock/voltage you should be good to go....it takes some trial and error...but I wouldnt worry about the VOLTAGE itself causing issues...just the result of it....heat. ;)
more voltage = more heat = need better cooling
I've had systems run fine up to about 63-64C after that you're getting too close to problems.
Right now I have it at 3.22 at 1.55Vcore My temps in mbm5 show 41 idle and 49-50 after 1 hr of prime 95, Now there has been a lot of talk about the Max3 showing higher than actual temps and actual proof in this article.
http://www.bleedinedge.com/reviews/abit_asus_temps/abit_asus_temps_01.html
Should I turn MBM down by 10 degrees and take that as my true temp? I am running at 2-6-3-3, but feel I could get tighter. I am still at 1:1. Do you think I can still get higher?
You could do that, and I honestly don't know why I never did when I had either of my MAX3's....as they are reporting on average about 10C too high.....I'd keep pushin' if I were you, as if the MAX3 is reading 50C after an hour or Prime you've still got some room to stretch. ;)
Well at stock vcore I did ok for awhile, plaed about 2 hours of CODUO online and system froze, will boost up to 1.550 now and see.
I was running mine at 1.675V for a while with no problems, Northwoods aren't really pushed until past 1.75V, past that you only need better cooling.
I'm running at 1.6V right now, max temps are around 50C.
I have upped the voltage a little, still below 1.6V though. I do believe I need better cooling before really taxing this thing. I am looking at the koolance exos on newegg as a WC alternative. However due to the fact we are moving in a month I am not sure I even want to deal with it until later. Will the sp-90 fit on the max3? A buddy is selling one and the fan for $20, maybe that'll help I currently have an aerocool 4 or something like that. Thanks for the input!
If you're running something as bad as the Aero4 then yes, the 90 should help a fair bit....and I'm pretty sure it fits the MAX3...check around though.
The EXOS would be good if you don't wanna dink around with building your own h2O system...and it actually should perform fairly well for you....definitely enough to get you pushin' that chip of yours a little more.
I'm runnin 55C max right now.... my voltage is at 1.575, to my knowledge teh aerocool doesn't blow much air? I'm just usin a Tt copper heatsink and a UFO series fan and I took that annoying grill with teh schizo LED's on it off, I've been able to hit over 3.6 with this CPU but it wasn't rock solid stable, but then again I didn't up teh voltage much
1.575v is pretty good if you've got it sittin' at 3.5GHz......I think I just had a bit of a bad 2.8C....cus I NEEDED 1.75v or so for 3.5GHz.....but then she scaled all the way up to 3.9 with 1.95v and h2O. ;)
Keep pushin'....but I'd get some better cooling in place to drop your load temp down from 55C before going much farther if I were you. Even if it's not dangerous....even if a CPU is technically capable of a certain clock....it might not be under warmer conditions....and often times, even though 55C isn't THAT hot.....temps like that can still limit an OC...depending on how far you're trying to take things.
see the ratios are your friends
Looks like you've got a pretty good OC going now:
3.5Ghz at 250FSB (1Ghz QFSB)
5:4 ratio puts your 3200 right at spec, so you should be able to use some tight timings, for low latencies.
Ok I got to 3.5 at 1:1, here are my settings. 1.65 Vcore 2.8 mem 1.6 agpV, 2.5, 7, 3, 3 but when I ran 3dmark it froze. Could my mem timings be off which causes the freeze? I am done for the night with it, but was wondering advice from here. I guess a 5:4 may help. Will try tomorrow, but all advice is welcome.
Try 5:4....could be the memory timings.....as 3-3 is fairly tight for 250 1:1 on my ram....depending on what you're running of course.
Could be the memory timings, could be cpu voltage.......who knows...have you tried doing anything else with that OC applied?
I forgot everything I tried, but will start with a fresh slate tomorrow. I am running the gskill ram which is suppsed to be awesome. I just want to get it to 250 stable. I'll probably back it down to 240 for 24/7 use. I am getting a xp90 from a buddy tomrrow to see if that helps. I'd like to keep the mem at 1:1 if possible, but that seems less likely. However I am getting to the boot screen and into windows now at 1:1, when yesterday I had to use 5:4 to get it to work. I guess finetuning just takes time and practice huh.
GSkill is very nice stuff....but the thing is that TCCD sucks ASS for Intel.....a lot of ppl over at XS are having issues getting it overly stable at the kind of clocks you're pushing....I wouldn't be surprised if it was something to do with the ram.
Wish this would have came to light before I shelled out 260 at the egg for this stuff. Trust me I am going to get this stable soon, but it is frustrating at times. I am even considering water cooling. How much is a decent AMD rig. I shudder at the though as I have been a P4 diehard, but I guess I should try AMD at some point to get an educated opinion, right.
I'm not sure what american prices are lookin' like (check the egg)....but if you want a very capable benching A64 without breaking the bank you could pick up an MSI Neo2 and a 3200+ to go with your GSkill you've currently got. Even a 2.5-2.6GHz 3200+ is going to be having its way with a 3.5GHz Northy anyways....and at least then you'll actually get something out of that ram of yours.
If you wanted to go one step further you could spring for a DFI nF4 board....but it'd mean switching off to a PCI-E video card also....so you may not wanna go that route.
Yeah I looked at the nf4 last week, but I do not want to do a complete rebuild of a system. my financial advisor (ol lady) would likely have me adjust my residence to the couch! I'll get it eventually, but prolly not right now.
Haha, good call.....I'm not a big fan of the couch myself. ;)
