Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
hey, its a 1/4 thread... What happened is, i don't have enough clearance between the bottom of my case and the bottom of the water block. So in other words i can't get the tubing to fit between the to areas without kinking the tube. So i need some type of elbow fitting or "L" bend fitting that will screw into a 1/4 threaded EK8800GTX/ULTRA water block and attach to the tubing. Any help would be great, i've looked everywhere and can't find anything.
