Cantonious
- Jun 22, 2003
3/8" OD fittings have more throughput than 1/2" OD?
3/8" fitting, on my not so scientific measuring stick..
1/2" on the same pen, notice the line from the 3/8" fitting! It's up higher, at a wider spot on the pen!
Am I crazy? Will using 3/8" tubing in fact be more beneficial than 1/2"? I understand that the 1/2" tubing has more volume in it, but if it's restricted by the fittings is it really worthwhile?
