Sysjack
- Oct 6, 2003
I've been working on a friend's new system for the better part of the day today, and we can't get WinXP to install. After the drive is partitioned and formatted, it loads drivers and whatnot, but before restarting to load the windows install GUI, it grives a BSOD and one of two error pages, one of which shows a stop error 0xC2 BAD_POOL_CALLER, with the other being 0x00000024. There are several other codes on both screens, but I didn't write them down. The error codes can be found HERE, with the 0xC2 code further down on the list to the left. System specs are:
AMD Althon 64 3200+ (CG Rev Clawhammer)
Abit KV8 Pro socket 754
512x1 Kingston HyperX PC-4000
GeForce 4 Ti 4200
Creative Audigy 2
Maxtor 80gb HD
Dynex 16X DVD-ROM
Antec Smartpower 350Watt
The CPU is definitely not overheating at present. It runs around 38C idle at 32C ambient. It may have overheated before I looked at it however, as the heat sink was improperly mounted (very loose) and there was far too much thermal compound on it.
Any ideas what is causing these problems?
Thanks
GeForce 4 Ti 4200
Creative Audigy 2
Maxtor 80gb HD
Dynex 16X DVD-ROM
Thanks
