Nazo
- Apr 2, 2002
One annoyance I keep having to deal with lately is my 0404 PCI will just randomly go silent sometimes after I start up my system. Basically it just won't have any sound coming out the analog (I'm not sure about the digital -- basically it IS my DAC) even though the PatchMix software might even indicate on the decibel meters that it thinks there is sound. From then on, simply rebooting or whatever doesn't really seem to help anything. I tried messing with volume controls (even muting then unmuting channels just in case one were internally stuck so to speak) and it didn't help. However, if I tell the PatchMix software to restore all defaults, it will fix it. This is EXTREMELY annoying though because it forgets any settings with volumes/etc and a reboot is required to get it to work. Then after the reboot I must again set it to not load FX on startup (this just adds an annoying unnecessary delay for me as I'm using this soundcard more as a DAC than anything else and thus never touch the FX) and I usually prefer to disable the splash screen while I'm at it. Then I have to go in and change the clock back to 44.1KHz (because, for some odd reason, most of my CD rips are in 44.1KHz rather than 48KHz. I have never understood why 48KHz became the norm for such things when it should only be needed for things like DVDs/etc as music -- which needs the quality the most -- will almost always be 44.1KHz.) I tried updating PatchMix, but, unfortunately, this did not do anything that I could see but give me another skin to choose from. Everything else about it appears to be exactly the same and the bug is as well.
I presume no one has ever found a way to run these without PatchMix, right? Honestly, I don't really need all of the stuff it does in the end anyway. I just need it to accept a digital input and output everything to analog. Pretty basic stuff that most soundcard drivers will do by default until you specifically tell them not to anyway.
