Ryom
- Oct 11, 2006
I see it very clearly watching Avatar: The Last Airbender DVDs and playing in darker areas of games like Just Cause 2 and Quakelive. If you've got the set in torch mode it probably won't be noticeable, but if you've got it set for theater viewing you'll see it clearly.
I tested the 810 for this as well, it does the same thing... albeit to a much lesser degree. I only had a few minutes with the 810 so it wasn't as in-depth as I would have liked and the settings may not have been identical. Also I read a post on AVS claiming the 810 had nearly double the input lag of the 700 (30ms to 16ms) with both in game mode.
