Hello everyone,
Ah, good news. My Wife has just informed me my PMP-400 heatsinks have arrived - yeay - now I can finalise my water-loop, and get those 2x DDC3.25's into action.
Post pics soon!!
Then, been to and fro wrt my PSU, and sleeving et al -> well, here's the idea:
Ordered the following from HobbyKing, for a total of $198-, and then $48 for shipping - high quality very flexible/soft/noodle-like silicone wire - on the 16AWG wire, there's something like 660 very fine strands making up the core......
Nice.
9680 Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK 100M
9654 Turnigy Pure-Silicone Wire 20AWG (1mtr) Black 50M
10936 Turnigy Pure-Silicone Wire 24AWG (1mtr) Black 50M
So, what a I going to do with this -> well, I considered all sorts of modular PSU's out there, but, just could not get it over my heart to dump my 5 year old PC Power&Cooling 1KW, 3x 12V rail TurboCool unit. We all know they are not modular, and the cables they come with are of a good quality, but really stiff....and difficult to work with in the confines of a PC, especially the BlackBird setup.
So, I will completely rewire this old stalwart with even better quality, but super-fexible, high-temp (yeah-yeah, I know) silicone wire. Color=black, black,back.
Let's see if I will still need sleeving afterwards, I doubt it, as this cable will look very good, and server-like - it has a real thick silicone jacket, and will fill the ATX- and other Molex connectors very nicely.
Order will arrive within next 2 weeks or so......
Exciting times ahead for my dear PSU, so all old cables will be desoldered, and new ones fitted, and tailored to exact length for this setup. Told you the wiring was going to be special
I will post a few pics of the pumps and new heatsinks tonight.
A while ago, I got the (pretty decent) TMS-200 from Koolance - for those that don't know, the TMS-200 is simlar to the Aquaero5/mCubed bigNG, where you can install a few temp sensors, and fans, and use curves/graphs/setpoints to automatically control said fans and/or pump(s) to specific measured variables or manual setpoints, or a combination of both.
The problem is, I am running Windows 2008 R2 on this setup, which is a must for the process simulator I have installed on here, and, the TMS-200 doesn't run under Server 2008 R2 I only realised this after I have installed it, made up cables, rewired temp-sensors, et al.
It would have been pretty easy to dump this, and refit an Aquaero5, for example, the only problem is the TMS-200 doesn't use std thermistors - only the later TMS-205 use the same ones as the bigNG and Aquaero5. So it means I will have to replace all custom thermistors-, fans- and pumps cables with new ones....a pretty time-consuming exercise, considering these were all made up of Turnigy silicone wire.
