Domingo
- Jul 30, 2004
you mean spells, like a wizard or a witch would use? that would be the point... its also explained that you usually have to do one of the spells first before normal attacks do damage. it also teaches you how to chain it all together...
edited speelin
I fully understand how it works, it just makes battles particularly long because you're always waiting around for your special attacks to charge up. Just like in AC: Odyssey when you're running around waiting for those attacks to charge up. That also ties into the whole leveling system. I've been fighting the same spiders since I was level 3 and both of our attacks do the same amount of damage at level 25.
