Pure electric cars are a deal breaker compared to the reliability and cost of a standard car of the same size in my opinion.
There has been much research in hybrids but I really think approached is wrong.
I think there needs to be a departure from batteries all together and instead use high capacity storage caps. Also the idea that you shut the engine off and run on the batteries is totally the wrong approach to a hybrid.
Sounds like you don't own a hybrid.
While a Hybrid might not be the best choice for everyone, it works for me. My commute is 100% city rush hour traffic, and I get almost double the mileage I got out of the non-hybrid version of my car (Camry) I had before. Much of the gas savings comes from shutting down the motor while I'm sitting at the long red lights, and with the Hybrid it means that the air still runs while I'm sitting there in the summer heat. I'd get even better mileage with a plugin hybrid, but the added cost of the larger battery, and the loss of trunk space doesn't make sense for me, even at $4+/gallon for gas.
What I like about the Camry hybrid, is it looks (inside and out) and drives like a normal car.
Most electric cars have several problems:
1. High price for what your get (even with the huge subsidies and tax rebates)
2. Long charging times (even Tesla's 30 minutes to charge the battery to half full is not good enough)
3. Short range, especially if you are driving at highway speeds or using the heat/air
4. Weird compromises such as ugly aerodynamic designs, lack of a spare tire, limited trunk space, etc.
If I might consider an electric car if they could build one with a 400 mile range, that would charge in less than 10 minutes at charging stations as plentiful as gas stations, and that looked like a normal mid sized car, complete decent trunk space and a space tire.
Don't see this happening any time soon, and considering battery technology, I doubt they will ever fix the charging time problem.
While an electric car with a 100 mile range would cover 90% of my driving, what am I supposed to do the other 10% of the time? The added cost of having another car just adds to the costs.
