B^gD^ddy~CF~
- Nov 5, 2006
This CAT is missing the SDK, this causes all kinds of weird behavior if you try to cleansweep/atiman to remove prior CATs.
The simplest solution is to install 12.2 or before, then install this RC right over the top allowing CAT Manager to handle uninstalling necessarily components.
This will fix the AB OC issues, as well as the GPU-Z cat reporting issue...
The only thing ive found wrong with this release is after a length of time, powerplay ignores any unlocked vcore increases, and reverts to the bios default causing GPU resets if youve upped vcore and not flashed it to the bios.
I don't overclock so I can't really comment on that portion. But when I look at the installed components under the AMD Catalyst Install Manager I do see the AMD APP SDK runtime. I only ever do clean installs so if that's the SDK your speaking of then it is included in the pre-certified drivers. I've encountered no other issues with these pre-certified drivers other than they were missing those two files, and they continue to have the scaling bug when BF3 is launched from an Eyefinity grouped desktop but played at a single monitor resolution. I did notice however that GPU-Z and Afterburner don't seem to agree with each other as far as what the clocks are staticly stated as being versus what AfterBurner measures in real time.
Lets not forget the eyefinity prob launching BF3.. = BSOD for me.
You have an extreme configuration to be sure Eclypse. If I remember from earlier in the thread you said you only get the BSOD when you try to launch from more than one screen. Am I taking it correctly that by that you mean that when you launch from Eyefinity grouped displays you get a BSOD? Do you get the BSOD when you launch the game from an extended desktop or mirrored displays? This sounds like it could somehow be linked to the BF3 Scaling Bug but more extreme in your case. When I launch BF3 from Eyefinity desktop and the game is configured to play at a single monitor resolution then the scaling completely breaks. One card gets used completely while the other pretty much sits idle. When I launch the game and configure it for an Eyefinity resolution the game scales across the cards just fine. I'll have to test and see if launching from an Eyefinity grouped desktop to an Eyefinity resolution in the game gives me a BSOD. I usually play at a single monitor resolution so when I've tested it I've always just changed it while in game and not left it that way because the performance is not what I would want for competitive gameplay. Ok I can confirm that launching from an Eyefinity Desktop to an Eyefinity resolution did not cause a BSOD on my two card crossfire setup.
My only guess at this point is that it's just something they have yet to recognize and work out that affects crossfire setups with more than two cards. Judging from your setup alone I'm gonna guess you've already checked the file integrity of the pertinent hard drives, done an SFC /scannow to make sure there are no corrupt system files, done a "repair install" file integrity check on the BF3 files from within origin, and made sure you've used the latest PBSetup to make sure you have the latest PunkBuster files(for some reason this doesn't upgrade on it own from time to time). That being the case I would drop them a line with as much pertinent system information as they need here after you've made sure the issue is not in the knowledge base articles.
