Markus.Schragner
- Aug 8, 2011
If i were to issue a "zpool replace tank olddisk newdisk" command on a raidz2 pool, is the pool for the time of the resilvering under greater risk?
I'm in the process of replacing a 10Disk x 3TB raidz2 pool with 10Disks of 6TB WDs. All "old" disks are fine and the last scrub had no errors.
Is it maybe even possible to issue all 10 disk replacements at the same time? I mean as long as all disks are working fine i would assume a direct sector to sector copy from the "old" to the "new" disk. Performance-wise it would be more clever to mirror the disks instead of rebuilding the "new" data from all disks.
Does anyone have any inside how zfs replace handles this case?
I'm using OmniOS
I'm using OmniOS
